VENOM 400 Performance Control Modules
Old Feb 26, 2007 | 01:45 AM
i_drive_stangs's Avatar
i_drive_stangs
Default VENOM 400 Performance Control Modules
does this thing actually do what it says or what?
and if you scroll down on this page to the 1996 mystic cobra what size tips do you think those are? 3.5" or 4" or what?
modified mustans 1996 mystic cobra.
thanks for the help.
Old Feb 26, 2007 | 02:49 AM
amrcnidyot's Avatar
amrcnidyot
Default RE: VENOM 400 Performance Control Modules
not sure on the venom thing. looks like it might work. and install looks really easy. the tips look like they are about 3.5"
Old Feb 26, 2007 | 05:56 PM
Whitecomet25's Avatar
Whitecomet25
It works, i have one and my Stang seems to be faster when its on . It has a betteracceleration rate.Install took me 5 min, you connect onecable tothe maf sensor and the other on the tps sensor then pos and neg on the battery.The only problem its when its on you do loose some miles per gallon. It can be turned off at any time when the engine is not running.
Old Feb 26, 2007 | 08:37 PM
i_drive_stangs
could you actually feel the difference and does anyone know exactaly what it is that it does?
Old Feb 26, 2007 | 11:16 PM
raz54's Avatar
raz54
It says it will work with a chip but do you need a chip or does it do it alone? Have you tested it at the track to see what difference to your ET?
Old Feb 26, 2007 | 11:59 PM
nanaki's Avatar
nanaki
Retired MF Moderator
is this thing basically like the $10 "chips" you get from ebay but with an on/off switch that fool your computer thinking you're running cooler than you are?
Old Feb 27, 2007 | 12:10 AM
v6stang07's Avatar
v6stang07
i dont think its worth 300, and the tips dont look 4" so ill say 3.5
GTJIM
Sep 23, 2015 09:59 AM
LivingInThePast
Sep 16, 2015 12:20 PM
Sep 8, 2015 11:50 AM
M3hunter
Sep 5, 2015 03:42 PM
