Question...
Old Mar 6, 2007 | 01:42 PM
GD2K6's Avatar
GD2K6
Default Question...
I finally got a hood scoop for my 99 v6. Does anybody know where i can get a template to install it? I've heard its not all that difficult, but drilling holes into my own vehicle isn't something im crazy about.
Old Mar 6, 2007 | 01:43 PM
Jefferson's Avatar
Jefferson
Moderator
Default RE: Question...
https://mustangforums.com/m_1997576/...tm.htm#1997576
Here you go, this is from our how to sticky at the top of the section.
Old Mar 6, 2007 | 02:14 PM
ZZmustang's Avatar
ZZmustang
Banned
The GT hood scoop on a 6 hood is tricky. I did this to my wife’s car, They will fit but its real close and the blots under hood are kind of at an angle.
And , you can't mount it in the same place as the GT hood, because of the lowered area in the hood. Good thing is, that there is about a 1 inch flat spot under the scoop, so you and be a little off and it will work. Drill the holes bigger than needed and use washers, this will allow you to move the scoop to make it look right. Use a long drill bit to get threw the bracing.
Under the hood where the drill came threw in the bracing , drill a 1 to 1 1/4 inch hole to get a socket wrench in .It will look good when done though.
Old Mar 6, 2007 | 02:16 PM
tommy2273boy's Avatar
tommy2273boy
If you want, ill snap some pics of my underhood
Old Mar 6, 2007 | 02:17 PM
GD2K6's Avatar
GD2K6
that would be cool for you to do that. I Have the general idea but i dont wanna screw this up.
Old Mar 6, 2007 | 02:32 PM
tommy2273boy
okay, here are couple pics...the car really isnt that dirty
it looks like the hood shows you where to bolt it on, unless its just mine, not sure if V6 hoods have same design.
Dalthius
Jan 19, 2006 03:56 AM
Scooterman
May 12, 2005 11:44 AM
black89gt
Mar 12, 2005 08:08 PM
SCARFACE
SVT Forums
May 6, 2004 05:12 PM
karma279
Oct 27, 2003 07:18 PM
