help transmission problems!
Old Nov 3, 2004 | 08:40 PM
terramir's Avatar
terramir
Default help transmission problems!
well my engine is running for once :P
2.3L piece of crap 1986 LX
But here are my symptoms and I know it's my transmission
#1 I can't get out of first gear in drive it just revs up to like 4000 rpm
#2 it's slipping while this is happening
#3 but I can shift manually into 2nd gear
#4 the engine shakes really badly in drive when I am at a stop light matter of fact the whole car shakes but if I shift into neutral the shaking stops
#5 it makes an ugly noise when I shift into reverse as well as when I shift into drive from neutral.
terramir
Old Nov 3, 2004 | 09:21 PM
DaGGer's Avatar
DaGGer
Default RE: help transmission problems!
well i am eather thinking that your clutch is gone or that there is something really bad going on in it....i have an 1985 jeep cherokee and i blew the **** out of it when it was slipping like you say that yours is and i can still get it to move in 4th and 5th(the only gears left) so let just hope that doesn't happen to you...maybe there is something wrong with the gears
Old Nov 3, 2004 | 10:20 PM
slegos888's Avatar
slegos888
well since he said it was in drive i think he has an auto!! umm i dont know what is wrong with it but, ford trannies svck so i would ask a transmission guy and find out if it can be rebuild or it you need a new one!
Old Nov 4, 2004 | 03:37 PM
terramir's Avatar
terramir
I might get a new one but I read in the chiltons manual something about ajusting bands could that be what's wrong here?
anyone konw ford trannies well enough and yes it's an auto
help
terramir
Old Dec 22, 2004 | 12:25 AM
ATL_STANG's Avatar
ATL_STANG
first check the fluid level if its full try changing the fluid and filter
Old Dec 22, 2004 | 12:28 AM
fast83gt's Avatar
fast83gt
ORIGINAL: ATL_STANG
I agree. I've fixed a few automatic trannys by changing the fluid and filter.
Old Dec 23, 2004 | 03:54 AM
351stangguy's Avatar
351stangguy
hey bro did you check the headlight fluid?
mine did the same thing a while back it cost me 400 bucks i put a rebuilt in it. what color is the fliud, does 1st 2nd and 3rd work when its in 3rd?
Old Mar 14, 2007 | 11:15 AM
skull88's Avatar
skull88
yea, I have an 83' Mustang convertable automatic. I traded a cadillac 90' sevillie for it, and it leaked like you wouldnt believe out of the tranny. Well I fixed all that when i took it to the shop. After that it drove but we had to adjust the distributor and idle. Now when in park it idles kinda high but when you put it in drive, it cuts way down but dosent stall anymore. Now 2nd gear slipps, its not real bad yet. I'm going to get some Lucas Non-Slip tansmission conditionor. I hope this fix will last a couple of months till I can replace the tranny. Took it out on the highway and it flew, just going up two way highway hills at around 55mph 2nd gear starts to slipp. In town it has to ease into it, and it doesnt always do that. Well we'll see what happens I guess.
04stangman
Sep 26, 2015 09:33 AM
showoffzx2
4 Cylinder NA and Turbo
Sep 14, 2015 08:40 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
vintageaion
Sep 8, 2015 10:45 AM
