HELP QUICK!
Old Mar 8, 2007 | 07:48 PM
amrcnidyot's Avatar
amrcnidyot
Default RE: HELP QUICK!
to get the headlight **** off, there is a small little metal release thing inside a slot in the side of the lever. you have to pull the switch out so the lights are on then turn the **** till you can see the slit. then you will need a very small piece of metal or screwdriver or somethin to lift up on the metal thing inside the ****. after that there are 2 screws on the top of the bezzle that you can see really easy. unscrew those and that will come off. then like cominus said, there are a few screws all the way around the gauges. undo those then it will come out.
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
svfetter
Oct 5, 2015 11:39 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
Sep 25, 2015 06:30 PM
