02 sensor help
my car is having problems starting andat idle and im getting terrible gas milage..will a bad o2 sensor effect my MPG and make my car run lean?
can I replace and o2 sensormyself? if so where can i get one cheap?
it could cause that to happen, usually it will throw a check engine light though. they arent cheap and you wont be able to find them cheap. they usually run 50-60 bucks a piece. you have 4 of them, 2 front and 2 rear. thats a good 200 bucks. and yea you can replace them yourself. the fronts can kinda be a pain but its not too bad. they just unscrew.
u scan tooled it i was going to say do that for 1 and if it was a rear 02 you could just get mil eliminators and problem would be solved and you would be good if u ever did decide to go catless
jwog666
Dec 27, 2021 08:09 PM
TfcCDR
Sep 14, 2015 12:08 PM
