3.8 Help
Old Mar 16, 2007 | 02:53 AM
art02gt's Avatar
art02gt
Default 3.8 Help
My friend is having trouble making his 97 V6 run. The car was in an accident about 6 months ago and the car had been out of use since. The damage was in the back and most of it was cosmetic damage except the gas tank got bent a little. The car starts and and does the normal rev to about 2k rpm, but it immediately dies. After replacing the fuel pump and filter itwill runbut only if you rev it pretty hard. If you don't keep the pedal pressed it will die. Fuel pressure is normal and we just can't get the car to keep running. What can be wrong?
Old Mar 16, 2007 | 03:28 PM
art02gt's Avatar
art02gt
Default RE: 3.8 Help
Nobody?
Old Mar 16, 2007 | 04:09 PM
gxszone's Avatar
gxszone
If at idle the car has sporadic RPM's and dies off if you do not gas it then Iwouldimaginethe problem beingthe idle air control valve (IAC)
Old Mar 16, 2007 | 04:31 PM
art02gt's Avatar
art02gt
ORIGINAL: gxszone
Where is the IAC? This is the first time I've seen a V6 stang engine so I have no idea.
mrappe
Sep 26, 2015 10:16 AM
col2560
Sep 25, 2015 08:59 PM
J.casone400
Sep 12, 2015 10:01 PM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
Stilz
Aug 18, 2015 09:40 AM
