burnout
Old Mar 30, 2007 | 03:24 PM
lithiumx's Avatar
lithiumx
Default burnout
how do i do a burnout...i have a 2000 v6 mustang 3.9L....i can do one if i just drop the clutch and floor it....but my car starts moving forward....i want to do one while the car stays in one place....im guessing i pull the e brake...but i wana be sure before i try it...
Old Mar 30, 2007 | 03:32 PM
2002GTAUTOVERT's Avatar
2002GTAUTOVERT
Default RE: burnout
dont pull the ebrake unless you wanna damage some parts.. just rev to to 5,000 and dump the clutch
Old Mar 30, 2007 | 03:41 PM
raz54's Avatar
raz54
Default RE: burnout
You need to power brake it then. Get the rpms up, dump the clutch and then with your LEFT foot quickly stomp on the brake pedel while still giving it gas. Then you can sit in one spot.
Old Mar 30, 2007 | 03:43 PM
cominus's Avatar
cominus
Default RE: burnout
Don't do it. It's wont be that kool if you have an open dif.
Old Mar 30, 2007 | 04:02 PM
banginstang07's Avatar
banginstang07
Default RE: burnout
just use the heal-toe method... push the clutch in put your toe of your right foor on the brake and the heal on the gas rev it with your heal and dump the clutch... and btw r u sure its a 3.9 because i think they only made 3.8l v6's in 2000 but the 3.9l was in 2004
Old Mar 30, 2007 | 04:12 PM
Trigg's Avatar
Trigg
Default RE: burnout
ya the 3.9 was put in, in 03 and 04. enless a engine swap was done.
Old Mar 30, 2007 | 04:49 PM
cisurfer's Avatar
cisurfer
Default RE: burnout
rev it up dump the clutch and use your clutch foot to stomp the brake and youll sit in one spot and let them roast then take your foot off the brake and driveaway still spinnin.....i did it yesterday its so cool
Old Mar 30, 2007 | 05:19 PM
eddiev22's Avatar
eddiev22
Default RE: burnout
engine swap from a 3.9L to a 3.8L? LOL naaa, hes just mistaken, hes got a 3.8L unless he mispelled the year then its 04, 03 were 3.8L too
Old Mar 30, 2007 | 06:24 PM
lithiumx's Avatar
lithiumx
Default RE: burnout
ya it is a 3.8...i was just thinkin about the 3.9's at the time so i wrote it in accidentaly...
by the way...ya only one of my tires spins...i know its cuz of the differential...but...wat the ****.....i dont wana replace the differential just to be able to do a burnout.
Old Mar 30, 2007 | 08:28 PM
cominus's Avatar
cominus
Default RE: burnout
ORIGINAL: lithiumx
If you have traction control on you wont be able to do it.
