Rough run after warm
ORIGINAL: 98Ga
clean your iac
clean your iac
Unfortunatly that doesn't work most of the time since you can only access a small portion and not where it gets sticky. If you take it in to a shop they can hook up their computer and cycle the IAC to see if it's actually opening or not.
well mine iac was fine, not that i looked at it but my car has been hooked up to a scanner and the only code i got was a misfire and that was when the car was sputterin
my coil is gonna b here fri, maybe thurs it ups is ahead, and it will b on there asap cause i dont play wit my car
it could b but i sure hope not, all my info has been form mechanics cause for the first couple days it did it thats where it was, they are bettin 90/10 that it is electronic which is an easy fix, the coil pack could be givin up after 7-8 yrs plus the heat is just hurtin the conduction even more
yea i know, the problem is there are so many variable, when i first had the problem, i got answers such as tranny, cats clogged, electrical, ecu, fuel pump, bad gas
u name the part, i could jst about cause it
hopefully we can figure it out, but 4 now im just waitin on dale jarret 2 pull up 2 my house
i changed out the plug wires asap and saw a lil improvement but it still does it when it gets hot
i still had the stock wires
i changed them to napa belden blue premium wires, thats what my mechanic suggested and they were only 40bux
ORIGINAL: Xtasy305
Well my 1999 dd v6 after you drive it for about 10 miles the engine starts sputtering and losing power (hesitating), it doesn't completely die but runs very rough. I let it cool for a few minutes and then go a few more miles before it does it again. The check engine light isn't on and there are no stored codes in the computer. The car does have a bad exhaust leak which I think is a blown manifold gasket. Any ideas?
Check the two driver side plugs closest to the firewall. They are notorious for fouling and causing a very bad misfire. Also check the passenger side spark plug wires closest to the radiator. Those tend to rub or get fried on the stupidAIR tubes. Again sever misfire.
If all that checks out check your fuel pressure. Your fuel pump may be dying.
