V-6 to V-8 engine swap
I have a 1994 V-6 stang with a blown motor. I have a 1988 V-8 roller motor from a lincoln. What mods or other parts do I need to make the swap. I want to go with a carb and not fuel injected.Will the V-6 trans work with the V=8?? Do I need differant motor mounts??? Would like help where I can get it. HELP! Located in Indianapolis, In. Any body close I can talk too?
Help, just high lite the problems. I can still rebuild the 6 and sell it for a V-8 car if its to much sh_t to swap. Let me know what you know. What you know could save me alot of sh_t. Thanks for your reply!
if your trying to get it as close toa 5.0 as possible in factory form and just have it carbed id say to start you need... a 5.0 k member motor mounts i think the stock trans could handle that under powered lincolon motor but you would probably be on borrowed time and going carbed im not to positive about the requirements but lower intake manifold carb and proper wiring to get it ignited in the car and so on so forth... i plan on doing a 8 cylinder swap to my 04 in a couple of years but i will most likely do a modular engine fuelinjected ,good luck to you
Sep 1, 2015 08:16 PM
