engine swap
Old Apr 4, 2007 | 11:39 PM
jmahle67's Avatar
jmahle67
Default engine swap
i have a 96 mustang v6 with a 5 speed and i might be getting a96 mustang gt engine will that bolt up to my 5 speed? what other thigns will i need to change to make it work?
Old Apr 5, 2007 | 12:14 AM
laserred38's Avatar
laserred38
Default RE: engine swap
not worth it for a NPI V8. although you CAN pick a used one up from MPS complete for like $600 bucks. you would need a beefed up rear-end amongst a LOT of other stuff. did the 96-98 GTs have T45s yet?
Old Apr 5, 2007 | 12:30 AM
jmahle67's Avatar
jmahle67
how wouldnt it be worth it? 150 or so hp vs 225 or so hp ? and id be getting it really cheap and its only got 40 some thousand miles on it?
Old Apr 5, 2007 | 12:43 AM
Xemeth's Avatar
Xemeth
It wouldn't bolt directly up. I THINK (don't quote me) that the bellhousing is different. Either way, there'd be a lot of parts to change out. If you could, look for a 99-04 4.6, they have PI heads and a lot more power. Or you could do a PI swap on the NPI 96 engine.
Old Apr 5, 2007 | 01:06 AM
laserred38's Avatar
laserred38
for all the trouble you could at least find a PI GT engine and have 260.
Old Apr 5, 2007 | 03:28 AM
88ttop5.0's Avatar
88ttop5.0
try and find a wrecked gt donor car for the rear end trans gauge cluster ecu and wiring harness, i would think the v6 trans could go on the gt motor i think on a different forum i read a post were some one was doing the swap and listed the parts as well and they were saying the tranny can work... ill see if i can find something or search on 3.8mustangs.com i believe. grab the motor and build it up on a stand for fun worse comes to worse...
Old Apr 5, 2007 | 07:59 AM
jmahle67's Avatar
jmahle67
well this engine i would be getting is very cheap and i know its in good condition and it still has a lot more hp than what i have now and until i save money i wouldnt be able to get a newer engine anyhow so y not buy this one cheap and use the money to make mods to it
Old Apr 5, 2007 | 09:51 AM
nanaki's Avatar
nanaki
Retired MF Moderator
as someone else said, an NPI motor isn't worth the time or money. you can get a low miles PI 4.6 for a few hundred bucks. hell, you can get a 5.4 for under grand.
Old Apr 5, 2007 | 01:28 PM
mustangman02232's Avatar
mustangman02232
a NPI motor will pull you from mid 16s to low 15s, a tbird supercoupe V6 motor will pull you from mid 16s to at the highest low 14s
unless its a 4V 5.4 dont bother unless you like to waste money
Old Apr 5, 2007 | 06:51 PM
jmahle67's Avatar
jmahle67
where would i go about finding an npi engine4 a few hundred bucks?
