Error code
Old Apr 12, 2007 | 09:57 PM
kippztha1's Avatar
kippztha1
Default Error code
I have a 2001 v6 and had a check engine light on for a few weeks. I borrowed my friends codes scanner and it came up PO404 Excessive EGR pressure. what the hell does that mean and is it something i can fix in my garage.
Old Apr 12, 2007 | 09:59 PM
laserred02's Avatar
laserred02
Default RE: Error code
ok it is most likely the dpfe sensor or something like that, it's $40 from advance auto parts. i had the same problem on mine, Ford actually issued an extended warranty on the part, but i was outside the 60k when mine went out. it's a simple change too, just unplug the sensor pull it out and put in the new one.
Old Apr 12, 2007 | 10:03 PM
kippztha1's Avatar
kippztha1
i appreciate the help. where would this dpfe sensor be?
Old Apr 13, 2007 | 01:35 AM
laserred02's Avatar
laserred02
it is a flat black sensor and will be i believe on the front of the engine next to the egr valve. it will be connected to the egr valve. i don't have a good picture to show you, but if you buy the sensor you will be able to see it, and replace it simply that i promise you.
Old Apr 13, 2007 | 04:49 PM
notasinger's Avatar
notasinger
Go to this web site and it will show you how to inspec, test, and install.
http://autozone.com/az/cds/en_us/090...rInfoPages.htm
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
TCStangerv6
Oct 11, 2015 05:57 PM
Dathan
Oct 5, 2015 05:52 AM
