Keyless entry
Old Nov 13, 2011 | 06:56 PM
  #21
belairbrian's Avatar
belairbrian
Originally Posted by 97greenstang
I guess I'm not seeing it, going to try again this weekend.
In the picture jkeaton posted you can't actually see the remote entry module. it is behind the black bracket. the pic i posted shows the bracket with the anti-theft module.
Old Nov 14, 2011 | 08:24 AM
  #22
97greenstang's Avatar
97greenstang
So you have to remove what ever box is shown on the above picture? Or, it's just behind it and you can still unplug the connector shown to program?
Old Nov 14, 2011 | 11:27 AM
  #23
belairbrian
The grey connector is not connected to anything. it's just there to get the car in program mode. My guess would be the dealer would have a mating connector with a switch to do it "properly". But a screwdriver does the same thing.
The important part is if there is a module behind the black part.
Old Nov 15, 2011 | 11:23 AM
  #24
97greenstang
So I looked this morning, the far back just has the fuel reset button, or what ever it is. The driver side wall appears to have that connector as shown, so this just means I have to find a keyfob somewhere and try and program, yes?
Old Nov 21, 2011 | 09:09 PM
  #25
97greenstang
jkeaton, reps to you, worked like a charm, got two fobs for $18.38 shipped, literally took me 4 minutes to complete all, now we have lock, unlock, trunk release and panic.
Old Nov 22, 2011 | 06:12 PM
  #26
jkeaton's Avatar
jkeaton
glad I could help out being a noob and all...lol
Old Dec 4, 2011 | 12:13 AM
  #27
Luis154's Avatar
Luis154
Do you guys know if this will be the same process on a 2000?
Old Dec 5, 2011 | 07:51 AM
  #28
97greenstang
I missed place the sheet that came with my fobs, I'll see if I can find it and let you know. It had all the years and the process on it.
Old Dec 5, 2011 | 06:15 PM
  #29
belairbrian
On a 2000 it should be:
1. Turn ignition from OFF to RUN 8 times within 10 seconds, with the 8th time ending in
RUN. Door locks will cycle to confirm programming mode.
2. Within 20 seconds press any button on first keyless remote. Door locks will cycle
to confirm programming.
3. Within 20 seconds, press any button on second keyless remote. Door locks will
cycle again to confirm programming.
4. Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
The good thing is you can use this procedure to verify you have remote entry.
Entering the programming mode erases the code for previously paired remotes so have all the remotes there. The system should accept up to 4 remotes.
Old Dec 6, 2011 | 09:57 AM
  #30
97greenstang
Bel, beat me to it, but the below is what the keyfob place gave me:
Here is for the 2000
