Random misfire?
Old Apr 26, 2007 | 10:38 PM
raz54's Avatar
raz54
Default Random misfire?
Hey guys. I installed my ASP 25% UDP today and then on the way home the 'service engine' light came on. I went back to the shop and hooked up the computer and it said there was a random misfire on cyl 1 & cyl 5. We couldn't see anything wrong so we cleared the code and after driving about 50 miles it came back on again. The car still runs fine and I didn't feel a misfire. The computer said the same thing this time. Is there some thing about the UDP that might be doing this? I know it has the sensor ring on it and I'm thinking I might have to put my old ring on the new dampner. Has anyone else had this happen?
Old Apr 26, 2007 | 11:06 PM
crusher101's Avatar
crusher101
Default RE: Random misfire?
all ivebeen told to watch out on the udp is to watch the idle on autos cause it may cause it to stall depending on variables
Old Apr 26, 2007 | 11:36 PM
v6stang07's Avatar
v6stang07
I dont see how a smaller pulley could cause that, an accessory shouldnt cause any misfire to occur, even if the alt was off u should still be okay, i dont think its related
Old Apr 26, 2007 | 11:56 PM
raz54's Avatar
raz54
ORIGINAL: v6stang07
Not the pulley itself. The new udp has the balancer and a crank trigger ring on it already and I'm wondering if there could be some thing wrong with the crank trigger ring since it started right after I installed the udp.
Old Apr 27, 2007 | 12:19 AM
v6stang07's Avatar
v6stang07
aahhh forgot about that one, is it a reputable pulley or ebay crap???
if it is from ebay then yes, put the stocker back on if not, i dunno, it could b but i have never heard of it b4
Old Apr 27, 2007 | 12:26 AM
raz54's Avatar
raz54
Yeah is an ASP brand and got it from Stang Mods. It cost $250.00 so it should be better than the stock unit so it really pisses me off plus I have to re-do the whole thing and hope that's the problem. I did notice #1 & #5 are close together on the coil pack so it's possible this is a coincidence but it's too weird that it started right after installing the udp.
Old Apr 27, 2007 | 12:43 AM
l_shizzle_l's Avatar
l_shizzle_l
did you have a little heavier foot right after you installed it? if so you might not of gave the engine enough time to get used to it.
Old Apr 27, 2007 | 01:14 AM
laserred02's Avatar
laserred02
ORIGINAL: raz54
you can try putting the old pulley back on and see if the miss goes away. it is possible that the trigger ring is not on properly. if nothing else you can take the trigger off the stock crank pulley and try that instead of the one ASP sent you, as there may be a problem with that one.
Old Apr 27, 2007 | 02:13 AM
raz54's Avatar
raz54
ORIGINAL: l_shizzle_l
I did a little on the first test drive but then later it threw the code and after clearing it I drove normal and it came up again. What would have to get used to it? The trigger ring and dampner are supposed to be the same size, it's only the pulley that's smaller.
Old Apr 27, 2007 | 02:17 AM
raz54's Avatar
raz54
ORIGINAL: laserred02
ORIGINAL: raz54
That's what I'm thinking too, to use the old trigger but it sucks having to do this again. If that cures it it won't be too bad but it still gripes my butt after costing so much. I'm wondering if one or more of the teeth on the trigger are bent slightly, if that could cause this?
