Bouncing problem
Old May 9, 2007 | 09:58 PM
defconfire's Avatar
defconfire
Default Bouncing problem
i have 4.10's and a posi on my car now and when ever i burnout my car bounces espically in reverse. any way to fix this?
Old May 9, 2007 | 10:13 PM
defconfire's Avatar
defconfire
Default RE: Bouncing problem
Anyone?
Old May 9, 2007 | 10:18 PM
Top Gear's Avatar
Top Gear
I've seen this problem posted on another forum before.. I'll se if I can find it
Old May 9, 2007 | 10:21 PM
defconfire's Avatar
defconfire
Thanks, I remember seeing it but couldn't find it.
Old May 9, 2007 | 10:24 PM
Top Gear's Avatar
Top Gear
http://www.moddedmustangs.com/forums...light=bouncing they seem to be saying it's worn springs or could be your control arms
Old May 9, 2007 | 10:25 PM
amrcnidyot's Avatar
amrcnidyot
its called wheel hop, new rear control arms can help solve the problem..along with other rear suspension components...but i think the control arms will probably help the most.
edit: and it doesnt mean something is wrong...it just happens, especially in reverse.
Old May 9, 2007 | 10:27 PM
defconfire's Avatar
defconfire
So its not bad for the car?
Top Gear's Avatar
Top Gear
it is bad read the post they said in the thread I posted
Old May 9, 2007 | 10:29 PM
v6stang07's Avatar
v6stang07
it is not good for the car at all, def try to take it easy in reverse because most will do it then, def change out ur suspension in the rear and u should solve the problem
Top Gear's Avatar
Top Gear
tomzac: "Wheel hop can really mess up your transmission including damaging the output shaft. Wheel hop is a condition caused by the poor geometry of our 4-link suspension which originated from the Fairmont. Aftermarket lower control arms will help, but stiffer upper control arms would not be a good idea. Unfortunately, they need to be sloppy unless you're only using your car for drag racing or don't plan on doing some hard cornering. Coilovers and a stabilizer bar using end link connections help too." - that's a quote from that thread, I'm not sure why this forum blocks me from saying that sites name....
