?Windstar CAI?
What kind of a CAI would I need to get in order to get this upper to work? It looks like a short under hood version just turned around, ofcourse the pic below is from a fox not an SN-95 like what I have. Or will i have tocustom make one?Opinions?
Ford Windstar 1996-1998 Upper Intake Manifold 3.8L
u can just find a kit for a mustang with the same size tube that has a 90 turn not a 75-80 like my car has and then just hook it up to run the other way and if the kit u get is a fender kit then ul have to either just use it short or boy a length of pipe the same size to replace the bend that goes int fender
You can also purchase a 97-99 F150 4.2L CAI.
Make sure to get name brand because the cheap ebay ones have a very small intake tube and restrict flow behind the MAF to the TB and will not support a larger 70 or 75mm TB unless a reducer is used.
junior04
Sep 28, 2015 10:53 AM
