V6 engine? problems help
Old Jun 1, 2007 | 05:33 PM
laserred02's Avatar
laserred02
Default RE: V6 engine? problems help
have the full flush done. they will change the pan gasket and filter as well. it's worth the extra money because it really cleans out the tranny.
Old Jun 1, 2007 | 07:16 PM
remoandiris's Avatar
remoandiris
Be sure they replace the filter and gasket. My co-worker was told by the garage they do NOT replace the filter. Guess there is no "standard" for the service.
Old Jun 1, 2007 | 07:35 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: the_1
I have an 01 v6 auto. Recently when I accelerate between 1500 and 3000 rpm the engine feels like it wants to stall(it jolts/doesnt respond). Because I already changed my plugs & wires, & i also cleaned the injectors with injector fluid cleaner, my mechanic says it might be the timing belt or the computer. Have any of you guys had this problem or have any suggestions... thanks.
Our cars are Timing Chains, not belt(s). I believe you may have reversed two of your wires when reconnecting the wires to the coil or the wires to the plugs. I've done it before. There are two wires in particular if you cross them the car will start and idle fine but want to fall flat on it's face when you rev it.
Check your firing order
http://z.about.com/d/autorepair/1/0/m/G/92714687.gif
Old Jun 1, 2007 | 07:43 PM
P Zero's Avatar
P Zero
Do a flush but DO NOT use that BG additive crap. It swells the seals inside your trans. BG tried to get us to use their product at the dealership I work at, we sent them packing.
But the way the flush machine works- is there are 2 containers 1 with new fluid and the other will be empty. You hook up the linesfromthe "flush" machine to the cooler lines and start the car. While its running one line sucks in new fluid and the other pumps out the old fluid into the empty container. Eventually all the old fluid is pumped out (by the transmissions pump), and that way all of the fluid is replaced.
As for the comment about draining the pan and the convertor, good luck with that. New cars dont have a drain plug on the convertor, and even if they did not all of the fluid gets out, some is left between the vaines inside the TC.
-P.
Old Jun 3, 2007 | 04:21 AM
lazypony's Avatar
lazypony
Is your SES light on? Even if it isn't, run an OBDII scanner through it. You could still be misfiring, even after replacing the spark plugs and wires. Check the coil pack, you could have a bad coil.
Old Jun 3, 2007 | 05:56 PM
bonsaicult's Avatar
bonsaicult
I've seen a loose torque converter to flywheel cause similar symptoms.... my 2 cents
Old Jun 6, 2007 | 03:45 AM
Tiny1987's Avatar
Tiny1987
Also a chance of it being the maf sensor
djbigskrilla
Sep 20, 2022 01:04 AM
ShaneB26154
35
Mar 4, 2021 04:05 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
HIS S-197
Aug 10, 2015 05:47 PM
Pain.
Aug 7, 2015 10:48 PM
