V6 engine? problems help
Old Jun 1, 2007 | 03:28 AM
the_1's Avatar
the_1
Default V6 engine? problems help
I have an 01 v6 auto. Recently when I accelerate between 1500 and 3000 rpm the engine feels like it wants to stall(it jolts/doesnt respond). Because I already changed my plugs & wires, & i also cleaned the injectors with injector fluid cleaner, my mechanic says it might be the timing belt or the computer. Have any of you guys had this problem or have any suggestions... thanks.
Old Jun 1, 2007 | 04:30 AM
laserred02's Avatar
laserred02
Default RE: V6 engine? problems help
do you have an automatic? old fluid will cause a shudder, if you haven't had a tranny flush in awhile get one done and it may take care of the shudder
Old Jun 1, 2007 | 04:40 AM
the_1's Avatar
the_1
it hasnt gotten a flush in... how would i do that or could i get it done at an oil change place?
Old Jun 1, 2007 | 10:06 AM
Ole Yeller's Avatar
Ole Yeller
to do a real flush you'll want to take it to a shop. you can change the fluid and that always helps, but a good flush will do more for yah.
check around on prices though, some places will really try and get cha for that.
Old Jun 1, 2007 | 02:28 PM
laserred02's Avatar
laserred02
ORIGINAL: the_1
yeah go to a local mechanic that can do a transmission flush, it will run $80-$100 at least where i'm at and it will be well worth the cost.
Old Jun 1, 2007 | 02:31 PM
Ole Yeller's Avatar
Ole Yeller
my shop does a full BG tranny flush for $150. definitly one of those things you want to do every 50K. keep your baby moving smooth and steady.
before you do it, think about adding a tranny oil cooler installed.... really keep her running forever.
Old Jun 1, 2007 | 04:44 PM
remoandiris's Avatar
remoandiris
How is a tranny flush better than dropping the pan, draining everything including the torque converter, and replacing the filter?
In a flush, the same old filter staysin there, right?
Old Jun 1, 2007 | 04:50 PM
Ole Yeller's Avatar
Ole Yeller
good question.
if it's anything like when BG does the ignition cleaning i would assume they hook up something and actually do a drain then clean, then fill kind of deal.
it's better in the way of it costs less would be my guess.
please correct me if i'm wrong
Old Jun 1, 2007 | 05:11 PM
remoandiris
Co-worker with a Jeep was quoted $140 for a flush. Replacing fluid and filter was $80. She went with the $80.
Old Jun 1, 2007 | 05:16 PM
Ole Yeller's Avatar
Ole Yeller
well what happens with a flush is they hook up a pump and actually pull and flush all the fluid out.
on an auto transmission not all the fluid is just in the pan. it's in the TC, the lines. just dropping the pan and cleaning out doesn't take care of all of the fluid.
