Starter Issue
Old Jun 14, 2007 | 02:44 AM
ProvingGrounds's Avatar
ProvingGrounds
Default Starter Issue
So whenever I have to start my car in the morning, I feel that I have to keep the in the ignition position for an extra couple of seconds. It feels almost as if the car doesn't want to start, but it actually starts. This problem dosent happen after driving the car for a while, parking it for an hour or so, then driving it again. Only if I keep it off for few hours or overnight. My battery tested fine... Any ideas?
Old Jun 14, 2007 | 03:43 PM
raz54's Avatar
raz54
Default RE: Starter Issue
Is it turning over OK or is it sluggish?
Old Jun 14, 2007 | 04:06 PM
ProvingGrounds
Sluggish for a second, then turns fine. I am thinking fuel filter or pump?
Old Jun 14, 2007 | 04:13 PM
laserred02's Avatar
laserred02
what year, is it nearing 100k miles w/o a tune-up. if so then put new plugs, wires, air filter, pcv valve, and fuel filter. that is a pretty basic tune-up. now this is assuming you don't have a charging problem. autozone will test your battery and alternator for you.
Old Jun 14, 2007 | 04:14 PM
ProvingGrounds
1999 with 105K
Everything is new except the Fuel filter. Battery and alternator are fine.
Old Jun 14, 2007 | 04:17 PM
laserred02's Avatar
laserred02
well change the fuel filter then and go from there, that should only run you $10-15. if you haven't done it before consult a haynes manual so that you don't get sprayed with fuel. plus you need a special tool to release the fuel line but they are cheap at any auto parts store.
Old Jun 14, 2007 | 04:33 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: ProvingGrounds
Take the starter out, clean it up, and have it bench tested. If it has dirt/oil build up, it gets softened after heating it up (driving around). Once it's back to room temp though the stuff is like glue.
Old Jun 14, 2007 | 05:59 PM
ProvingGrounds
I am still waiting for my manual. Where is the starter motor located? any write up out there on cleaning, etc...?
For the fuel filter, I found this website with VERY good write ups: http://www.bullittarchive.com/1000.htm
Old Jun 14, 2007 | 06:05 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Under the car. Put the front end up on ramps. It's between the passenger side exhaust pipe and the engine/tranny (tucked in) just under the passenger side exhaust manifold.. Be sure to take the (-) battery cable off before messing with it. The (+) lead on the starter is surounded by metal and if you get a wrench in there and touch it to metal (which you will) you could hurt yourself or damage your electrical system by causing a short.
For cleaning just go to any auto parts store and get electrical parts cleaner. CRC makes one that comes in a Red and White spray can. Has pictures of alternators and starters on it.You could use brake cleanerbut it takes longer to dry and could eat any plastic it hits.
Old Jun 14, 2007 | 06:09 PM
ProvingGrounds
Great, thank you
Any photo by any chance?
cr620
Oct 3, 2022 10:18 PM
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Dathan
Oct 5, 2015 05:52 AM
logan409
Sep 26, 2015 07:43 PM
