Cutting springs
Old Jun 18, 2007 | 06:19 PM
Deepenough's Avatar
Deepenough
Default Cutting springs
Hey guys, im cutting my springs either tonight or tommorw. Can anyone give me a quick run through of what i gotta do, what to take off etc... what tools i might need like to cut the spring and to compress it when taking it out if i have to etc. How much should i cut off because ive heard they will sag a little after i do it... just an overview of what i gotta do...
Old Jun 18, 2007 | 06:28 PM
laserred02's Avatar
laserred02
Default RE: Cutting springs
search for cutting springs in this forum and you will find several write-ups. this topic has been covered a lot the last month or so.
Old Jun 18, 2007 | 07:19 PM
raz54's Avatar
raz54
Do NOT use a torch, use a cut off wheel in an angle grinder or a sawz all. They won't sag after cutting because they already have, that's just on new springs. Also you won't need a compressor, just a floor jack and have the car up on jack stands. Make sure you reuse the rubber isolators or they will be noisy. The worst part off cutting them is you have to cut a little then reinstall it and let the car down and roll it to let it settle then see if it's where you want it and if not do it again. I wouldn't cut more than half a coil at a time because if you cut to much off you're screwed. You can get Ford's C racing springs for around $140.00 for a whole set. Plus they are stiffer for better cornering.
Old Jun 18, 2007 | 08:23 PM
l_shizzle_l's Avatar
l_shizzle_l
https://mustangforums.com/m_3383174/tm.htm
sticky's at the top for a reason
CS2007
Jun 25, 2019 09:45 PM
jrrhd73must
Oct 2, 2015 09:17 PM
mdg
Oct 1, 2015 07:04 AM
mungodrums
Sep 28, 2015 10:54 PM
