Cleaning the engine
Old Jan 13, 2005 | 07:18 PM
tightdogal's Avatar
tightdogal
Default Cleaning the engine
I popped the hood yesterday and i noticed.....my engine is kinda...dirty....Whats the best way to clean the engine? I heard about this foam stuff that is supposed to be sprayed on the engine...is that safe? also is using water safe as well?
Old Jan 13, 2005 | 07:50 PM
slegos888's Avatar
slegos888
Default RE: Cleaning the engine
yeah get a good spray on foam engine cleaner degreaser and spray everything except for eletrical connections. let is sit as directed and then just hose it off! you shouldnt have to worry about the water its not a big deal. then just run you engine for a lil bit to dry everything off and there you go! nice and clean!
Old Jan 13, 2005 | 08:17 PM
tyybo's Avatar
tyybo
2 words man.. Carb Cleaner. try it and you will be amazed at how well it busts grease
afte rthat then go to the cleaner stuff. and like slegos said. dont spray elect connections
Old Jan 13, 2005 | 09:26 PM
97Stallion's Avatar
97Stallion
I'm always a fan of good ole elbow grease too.
Old Jan 14, 2005 | 03:23 AM
HRnB's Avatar
HRnB
Administrator
Simple green straight, not deluted, but your engine has to be cool when you spray it on or it just evaporates. If you can hook your hose to the hot water conection for your washing machine or hot water heater, you can rinse it with hot water after the simple green sits for about an hour.
[sm=alcoholic.gif]<<do this while your waiting for the simple green to soak.
Nick Oliver
Oct 17, 2018 04:22 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
zachary1988
Sep 4, 2015 03:04 PM
5.0 kevo
Sep 3, 2015 06:24 PM
Sep 1, 2015 08:16 PM
