Forged Internals
Old Jul 4, 2007 | 11:09 PM
raz54's Avatar
raz54
Default RE: Forged Internals
I don't understand why some would need clearancing and some wouldn't, maybe something to do with the year of the block being made different. As for the crank if you get a used one you need to have it turned.
Old Jul 4, 2007 | 11:11 PM
eaglecatcher's Avatar
eaglecatcher
hmmm. I guess I'll just buy a new one to save the hassle.
Since my engine is pretty lowe mileage (64k), if I were to do my internals soon, would I need to have my block honed and bored out and all that good stuff, or would it be fine to leave it as is?
Old Jul 4, 2007 | 11:19 PM
jthorn9's Avatar
jthorn9
The Godfather
It's not required, however..............it would be a wise decision.
Old Jul 4, 2007 | 11:28 PM
raz54's Avatar
raz54
It would at least should be honed and if you are going to all that work (and expense) make sure to get the rotating assy balanced.
Old Jul 5, 2007 | 12:10 AM
eaglecatcher
alright, so if I were to take it in to get honed, what all do I take with me? Do I just strip the top of the block pretty much, or what? I should probably go look in my haynes manual, I read something in there about honing cylinders.
What about overboring? Would that be worth it, or does it have no effect other than if your cylinder walls are damaged?
Old Jul 5, 2007 | 04:04 AM
LilRoush's Avatar
LilRoush
ORIGINAL: eaglecatcher
If I did pull a crankshaft from an f150 at a junkyard, am I gonna have to do any clearancing, or will it fit normal? I found some kits on ssm that dont require clearancing, and some that may. How do I know if it will need clearancing or not?
Do a search for 4.2L swap and look for my posts. There are oil pan changes that happend, you need the 01-04 pan and a few other things, but it's basics...nothing too major.
Old Jul 5, 2007 | 04:14 AM
eaglecatcher
thanks, I'll take a look at those. I may juts go with the 4.3 Long Rod Stroker from ssm. Looks like a good kit, and comes with pretty much the same stuff for the same price. Are there any problems with that kit, or is it a good one to go with? Thats the one I'm leaning towards ATM, since it requires no clearancing.
Also, what compression pistons should I run? The procharger uses like 11psi, and it says good for anything like 9:1 and below I belive. So, should I go 9:1 or 8:1. If I go 8:1, could I run more boost than say with 9:1, or would it be best to run it at 9:1?
Old Jul 5, 2007 | 04:14 PM
TheMichiganRA's Avatar
TheMichiganRA
Don't buy from rpm-mustangs.com! Look at my last post for the reason why. "I need some help!"
NorthAmericanTuning
Nov 9, 2016 11:44 AM
EASTIDEE123
Sep 14, 2015 03:52 PM
Sep 8, 2015 11:50 AM
