3.8 injector problem
Old Jul 25, 2007 | 04:19 PM
Antera163's Avatar
Antera163
Default 3.8 injector problem
New to Mustang Forum..Lot's of GREAT information..
The question I have is I just did Head gaskets on my 1994 mustang 3.8 and used all the info from the forum,,,99+ headgaskets, new headbolts and so on.. The problem I am having now is that when I turn the ign switch to the on position # 6 injector has a steady stream, the other injectors are closed,, I was wondering if this was common problem on the 1994 because the previous owner replace the pcm 20000 miles ago for that same reason. I disconnected thewireconnectorto that injector and it shut off,, reconnectedand fuel came out.I checked for power and ground at the #6 injector teminal and there is both. So I figured since it receives the signal from the pcm. it must be broke..I did a ohms reading on the teminal from the injector to the pcm to see if it was grounded but it was good.. any other thoughts other than a new pcm...Thanks
SteelerNation82
Sep 16, 2015 07:11 AM
EASTIDEE123
Sep 14, 2015 03:52 PM
J.casone400
Sep 12, 2015 10:01 PM
uedlose
Sep 10, 2015 01:37 PM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
