front brake upgrade question.
RE: front brake upgrade question.
YEP! the bullitt brake kit with pony calipers are nice... i got the crossed drilled & slotted rotors for looks as well as performance.. make sure u get new brake lines too..
ORIGINAL: RyansQuick6
I used the Bullitt front setup, mainly because I didn't want "cobra" on anything on my car. Same kit, just with a pony on the calipers.
Ryan
Ryan
NEVERbuy Slotted/Cross drilled brakes off Ebay. Cheap is not better!!!!! Most of the time they are just stock brakes some redneck drilled holes in out back in his shop trying to turn a buck.
Cobra/Mach 1 set ups are more than 90% of the V6 Mustang world needs. And for the price, you can't go wrong. They are a straight forward install that anyone with a wrench set and a free afternoon can do.
ORIGINAL: LilRoush
NEVER buy Slotted/Cross drilled brakes off Ebay. Cheap is not better!!!!! Most of the time they are just stock brakes some redneck drilled holes in out back in his shop trying to turn a buck.
I agree you need to be careful where you buy them but if you do some research and only buy from a reputable company you can still get a quality product and save a few bucks in the process.
I too am thinking about doing the thing.
What year Mach 1 parts?
Just theMach 1 rotors, calipers and pads? same spindles or caliper bracket? (Ive never had my wheels off, I dont know how theyre on there...)
Are the rotors bolted on to the wheel bearing or are the bearingsin and wheel studs attached tothe rotors?
Are upgrades nessesery for the rear breaks as well? No proportoning valve to worry about and finaly, will they fit my stock ugly triangle wheels?
Thanks
Thanks
ORIGINAL: 3.8_Special
Thanks
Thanks
Unfortunately, no, the 13" Cobra brakes require 17" wheels for clearance.
Galactic
04-29-2019 02:56 PM
mungodrums
10-07-2015 04:01 AM
M3hunter
09-05-2015 03:42 PM
