A/C Problem: Only works on high?
Old Aug 8, 2007 | 09:57 PM
itscalledred's Avatar
itscalledred
Default A/C Problem: Only works on high?
I need help with fixing my A/C. It has been sitting for the past several months, and when I tried starting it up, it did with no problems, but when I try the A/C it blows both hot and cold air as it should. But it will not pump out any air unless it is on high. If it is on anything lower, I can feel very little air coming out, but it is still at the right temperature. What can I do to fix this.
Old Aug 8, 2007 | 11:02 PM
MantaDreams's Avatar
MantaDreams
Default RE: A/C Problem: Only works on high?
fan or fan switch. open the duct or access the fan. remove fan, squirrel cage should spin freely. "High" may be the only setting shoving enough current to this motor to overcome resistance.
Old Aug 9, 2007 | 10:44 AM
Derf00's Avatar
Derf00
Gentleman's Relish
Could also be the speed control relay/resistor for the blower motor. Usually the low speeds are the first to go because they are used the most. Check with your dealer see to find out where it's located...BEFORE buying it use an electrical tester to test your existing switch to make sure that is really the problem. If it is, then buy it.
Old Aug 9, 2007 | 11:20 AM
Xemeth's Avatar
Xemeth
99% chance of it being the blower motor resistor. I've seen it a bunch of times.
djbigskrilla
Sep 20, 2022 01:04 AM
Oct 5, 2015 06:07 PM
Omgitsa88Stang
Sep 1, 2015 06:31 AM
ccwebb
Aug 11, 2015 06:47 PM
HIS S-197
Aug 10, 2015 05:47 PM
