A/C not cycling
Old Aug 30, 2015 | 12:05 PM
Omgitsa88Stang's Avatar
Omgitsa88Stang
Default A/C not cycling
Hey guys I need a little advice I Replaced my a/c compressor on my 93 lx 5.0 and did everything right. I did not replace the accumulator (because I'm selling the car and it seem to be in good condition) everything works fine no leaks the a/c is cold right around 38-40 degrees depending on the temperature. What I did notice is that the comprossor is not cycling on and off it is steady going would this be this switch on the accumulator or another switch like a relay? Thanks any advice would be helpful.
Old Aug 31, 2015 | 08:46 AM
88 orangepeel notch's Avatar
88 orangepeel notch
Sorry I'm not familiar with AC stuff. Have you tried Googling this problem ? I'm sure this has happened to someone before. Good luck.
Old Aug 31, 2015 | 09:15 AM
Omgitsa88Stang
Yes I have tried googling it and only cycling on and off is what I find thanks anyways orange peel. Any one else that has had this problem?
Old Aug 31, 2015 | 07:27 PM
Omgitsa88Stang
Well I found out that it's normal at idle for the compressor to stay on and not cycle. When your driving it builds up pressure and that's when the LPS (low pressure switch) kicks on and shuts the compressor off for a few seconds. I believe it builds up pressure to 24-26psi. So at idle the compressor will stay on constantly. I hope this helps someone else BTW I found this out by my good friends at FoxResto.com
Old Sep 1, 2015 | 06:31 AM
88 orangepeel notch
Glad to hear, and thanks for the update. Really helps the next guy with similar questions.
mrtrodonet
Sep 19, 2020 03:12 PM
vargas
Jun 17, 2017 12:17 PM
69Volunteer
Sep 30, 2015 10:39 AM
SteelerNation82
Sep 16, 2015 07:11 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
