supercharge question
Old Aug 15, 2007 | 10:00 AM
HARFORD's Avatar
HARFORD
Default supercharge question
okay, so this wont happen any time soon i think, but if i was able to get a supercharger off of a supercoupe or somthing like that, would that bolt up to my 98 3.8L mustang? if not what can bolt onto the top of my engine with slight modification.
Old Aug 15, 2007 | 12:58 PM
xX98StallionXx's Avatar
xX98StallionXx
Default RE: supercharge question
You have to get alot of little parts off the thunder chickento make the super coupe blower work. not to mention its probably a better idea to beef up other parts to help it run more efficiently, differential, gear ratio, exhuast.. that sorta thing.
Old Aug 15, 2007 | 01:32 PM
hpwrestler220's Avatar
hpwrestler220
not to mention you need a dyno tune i think. than bigger injectors, a tuner, with some more power u will need the dual exhaust i believe?? but injectors a tuner and a tune are a def. it gets expensive quick. its not like you can strap the blower on and instantly have safe power for your engines internals and such
Old Aug 15, 2007 | 03:08 PM
HARFORD's Avatar
HARFORD
why do i need a dyno tune? what technically does a dyno tune do? i dont see why i cant by a programer and do the same thing on test runs at the track or whatnot
Old Aug 15, 2007 | 06:23 PM
xX98StallionXx
dunno about the dyno tune but If you feel like trouble shooting it yourself go ahead.
Old Aug 15, 2007 | 06:31 PM
svt_97cobra's Avatar
svt_97cobra
I ♥ Acer
You need a dyno tune to figure out your air/fuel ratio... If not you could run too lean and blow your engine...
chrisdbassplayer
Oct 13, 2015 06:53 PM
treesloth
Sep 28, 2015 07:03 AM
col2560
Sep 25, 2015 08:59 PM
