Power Boost
Old Aug 31, 2007 | 01:42 PM
robinson209's Avatar
robinson209
Default Power Boost
Whats up guys. I have a 2001 3.8L and I wanted to add a boost to the HP without spending thousands of dollars. What would you guys recommend for small boost at a reasonable cost?
Old Aug 31, 2007 | 02:30 PM
Xemeth's Avatar
Xemeth
Default RE: Power Boost
Gotta pay to play. Anything cheap won't give you ****. Nitrous is the cheapest way for quick power, though.
Old Aug 31, 2007 | 02:48 PM
robinson209
will exhaust do anything for me? thats not too expensive right?
Old Aug 31, 2007 | 03:13 PM
Xemeth's Avatar
Xemeth
Nothing more than sound. Maybe 1-2 HP on a catback, another 2 if you take off the cats. A total of maybe 10-12 with long tube headers, off road midpipe and catback.
The 3.8 responds like **** to bolt ons. So does the 2v GT. Only the Mach 1's and Cobra 4v's respond well to bolt ons.
Old Aug 31, 2007 | 03:43 PM
ryan1101's Avatar
ryan1101
K&N Air Filter with an Air Silencer removal will cost you about 40 bucks at your local Autozone or other automotive store. It will arguably give you about the same hp as a $140+ Cold Air Intake, which is 8-10hp, i think. That's usually people's first mod.
Aftermarket Camshafts are the best bang for your buck, running at around $200-250, i think. I'm not sure about the HP increase. It depends on other mods. After Camshafts, you'll wanna look at UDPs (Underdrive Pulleys), which are under $200.
Good luck!
Old Aug 31, 2007 | 04:33 PM
Xemeth's Avatar
Xemeth
ORIGINAL: ryan1101
Good luck!
Actually most of that is wrong. The air filter with no air silencer will give a similar gain as a CAI, but only like 2 HP if you're lucky. Not 8-10. That's rediculous.
Also, a camshaft isn't a good upgrade unless you have other mods to back it. You need ported heads and intake, and possibly a blower to see full potential. Also, if he's asking simple questions like that, I doubt he'd be installing himself. And cam install on a pushrod engine is a pain in the ***. You either take out the whole engine, or take out the radiator, fan, grill, and anything else in the way of the center of the block. Also, a cam that's not aggressive enough will suck if he plans on a blower. But if he gets a blower cam without a blower he'll totally lose low end torque. I don't know about price of the cam itself on a V6, but for a SOHC V8, they're about $550-$650 for two.
All in all, there's no cheap mod that gains a lot of power.
Old Aug 31, 2007 | 04:42 PM
2002GTAUTOVERT's Avatar
2002GTAUTOVERT
ORIGINAL: Xemeth
ORIGINAL: ryan1101
Good luck!
on my old 5.0 i took out the entire engine.. easier than removing a bunch of sh*t from the front.
the6 is a turd. (so is the 4.6) in terms of responding to mods.. if you guys could, id consider a 5.0 swap. its a pushrod with cheaper parts and alot more aftermarket options. i dont really hear alot about the aftermarker for the pushrod 6
jwog666
Dec 27, 2021 08:09 PM
TCStangerv6
Oct 11, 2015 05:57 PM
KingRando
Oct 2, 2015 08:06 AM
ChampInSD
Oct 2, 2015 04:55 AM
Sep 25, 2015 06:58 PM
