Window motor
My drivers side one Died on me. I figuewd out how to get the inerior trim panel off, but I cant figure out how to get to the motor...How would I go about getting to and changing it
If I remember correctly, look around the door panel sides. There should be about 2 or4 bolts holding it on but I could be wrong. It's been awhile since I've taken mine off but its not hard at all. It mostly just "pops" right in. Not hard to do at all. Wait, nevermind...here:
Doors panels:Unscrew the door locks. Pull on the door handle and gently pry the back of the door cup out, and remove. Pry up the window switch plate/door pull, unscrew electrical switch panel from the plate. Remove two screws found where the switch panel was located. Pry out the Christmas tree fasteners found on the edges, and pull the panel up and toward the rear to remove.
Of course, to put it back on, reverse the order! Hope that helps!
logan409
Sep 26, 2015 07:43 PM
