checking for dtcs
Old Sep 16, 2007 | 08:50 PM
tims 88 4's Avatar
tims 88 4
Default checking for dtcs
i know there is a way to check for dtc codes with out using aford scanner i cant remember how to do it so if someone could thell me that would help me a great deal
thanks alot guys tim
Old Sep 17, 2007 | 12:05 PM
johnt2k7's Avatar
johnt2k7
Default RE: checking for dtcs
hold the odometer button start the car when it flashes test release it and gauges will do a full sweep the click od again and all the bubls will light up again and it will give you your ecu number i believe and once mor and it will say DTC:NONE DTC: or DTC:11111 depending on what year your car is mine is random some times it saya DTC:none others it will be DTC: and a while back it gave me a DTC:with a 15 or 18 something but i was told that it was a oil pressure swithc and nothing was wrong that code gets thrown by the ecu and their is nothing realy wrong unless the check engine light comes on i tried using a real scan tool and nothing came up so i just dismissed it
mltdwn12
Sep 23, 2015 08:54 AM
gagemcc
Sep 22, 2015 09:43 AM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
