Cats.
Old Oct 7, 2007 | 08:02 PM
mustangred's Avatar
mustangred
Default Cats.
Lately i've noticed my cats have been starting to smell..so they are getting stuffed up. I have decided to have them cut off and just put some piping where they was Do you all think that is a good idea to do
Old Oct 7, 2007 | 10:25 PM
raz54's Avatar
raz54
Default RE: Cats.
If you live in an area that does not have inspections go ahead and remove them. You will need a couple MILs though for the 02's closest to the motor.
Old Oct 7, 2007 | 10:33 PM
94Blk5.0's Avatar
94Blk5.0
Default RE: Cats.
You would need MIL's for the 02's that were behind the now removed cats.
Old Oct 7, 2007 | 10:45 PM
XxXRacingUnleashed's Avatar
XxXRacingUnleashed
Default RE: Cats.
some times where the 02 is you can run the line up to the air pump and it will cancel out where the 02 is, make sure to run a pipe buit if you want a FAST temporary fix pull the cat out get a big drift and punch out all the platinum honeycomb filling out, its a free straight pipe plus you will still have to 02 in there (remove it before you hammer out the platinum)
Old Oct 8, 2007 | 03:05 PM
mustangred's Avatar
mustangred
Default RE: Cats.
yea i live in the area without any of the inspections now exactly what does the o2 thing do
Old Oct 9, 2007 | 01:47 PM
XxXRacingUnleashed
Default RE: Cats.
its an 02 sensor it helps with telling your ecu air flow kinda like the MAF
OfficerEd
Jan 13, 2005 11:42 PM
Jiggy_One
Jan 8, 2005 03:36 PM
ghost98
Nov 11, 2004 03:46 AM
ghost98
Nov 11, 2004 01:24 AM
