Headlights
Old Oct 13, 2007 | 01:46 PM
Marty86's Avatar
Marty86
Default Headlights
I just bought a 98 Mustang 3.8 V6 yesterday. I drove it home, and it was dark so I turned on the headlights, but they were not turned on. I had to turn the brights on in order for my head lights to work.
I pulled my headlight switch this morning, and it seemed to look fine, all the prongs, and spring looking thing looked fine. I tested them with the instructions in the Haynes manual, and it seems to be fine.
What could be my problem? Where should I start? I'm at a loss! I don't normally drive at night, but obviously I need them to pass inspection....
Old Oct 13, 2007 | 01:55 PM
joestang02's Avatar
joestang02
Default RE: Headlights
maybe the normal driving filament is burnt out, take your bulbs out and examine the filaments..maybe you just need a new pair of lights
Old Oct 13, 2007 | 02:00 PM
Marty86's Avatar
Marty86
All the filaments are good, I checked that.
Old Oct 13, 2007 | 04:04 PM
Marty86's Avatar
Marty86
Okay, I swapped out a headlight switch, and also blubs with new ones, not change.
HELP!
Old Oct 13, 2007 | 05:30 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
it's a fuse there pimp. There is a high and low beam fuse, and sometimes more than 1 low beam fuse.
Ryan
Old Oct 13, 2007 | 05:45 PM
jthorn9's Avatar
jthorn9
The Godfather
ORIGINAL: RyansQuick6
Ryan
+1
Old Oct 13, 2007 | 10:48 PM
Marty86's Avatar
Marty86
Actually, it wasn't. Turns out it was the turn signal switch. Our guess is that you know how for a second when switching between high and low beam, thats where the lights were stuck. Because the high beams worked, but not low.
Thanks chaps!
StalkerGT
Nov 28, 2015 03:09 PM
Seanam
Oct 4, 2015 10:15 AM
Drastang
Sep 29, 2015 03:31 PM
Mobiusone stang
Sep 7, 2015 08:46 PM
amandahchase
Sep 3, 2015 10:09 AM
