third brake light
when you open your trunk it lights up?? wtf. are you sure thats just not the courtesy light? are you other brake lights lighting up? stick a brick or somethin on ur brake pedal and go look at all 3 lights..
yes as stated the brake light lighting up is NOT THE BRAKE LIGHT. its that white light that allows you to see in your trunk when you pop your trunk at night. it only comes on when your braking. its put so close to the brake light it shines in and looks kind of lit.(maybe its on purpose to tell if your trunks popped at night or see where your trunk is if it was that dark whatever beside the point).
check the bulb(s). if not start pulling fuses (i dont see why the third light would be on its own fuse but whatever). then check to see if a wire broke loose somewhere around there.
Daddys Girls GTs
Sep 14, 2015 08:46 PM
Sep 8, 2015 11:50 AM
