misfire
Old Oct 31, 2007 | 07:40 PM
v6stang07's Avatar
v6stang07
Default misfire
well as yall probably know i recently cracked a header. I have been tryin to keep my cars fluids up, hoses good, and my battery charged by cranking it about once a week. I went to crank it the other day and it was sputtering and was missing real bad so i shut off the car. I thought that i could have water in the gas since we just had a cold front and that the gas was pretty old, like a month, so i went and got 2 gallons of new gas and added some fuel additive. Now I cant even hardly keep it running without giving it lots of gas. does this have something to do with only having half an exhuast system or somthing else. could a blown valve cause this misfire?
Old Oct 31, 2007 | 07:45 PM
baskplaya120's Avatar
baskplaya120
Default RE: misfire
Check to make sure ur spark plugs arent cracked ( mine just were and it was misfiring real bad) and make sure ur intake is on tight and there are no leaks i forgot to tighten mine back up and it fell off once and it would die without me giving it gas.. embarrassing i know but it happens lol hope it helps
Old Oct 31, 2007 | 10:17 PM
raz54's Avatar
raz54
Default RE: misfire
A burnt valve can make it run rough but not an actual misfire. Is it running rough or missing?
Old Oct 31, 2007 | 10:36 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Default RE: misfire
Will it power through the rpm range or jsut never pick up? Having a bad exhaust leak that close to the head can cause issues due to a difference in back pressure. Change your fuel filter too. Check all plug wires and plugs and check the coil for a possibly loose connection. And +1 on the intake, that little hose coming from the valve cover (PCV) and make sure it's connected. Mine has come out a few times and caused issues.
Old Nov 1, 2007 | 11:13 PM
v6stang07's Avatar
v6stang07
Default RE: misfire
it will pick up through the rpm range but it wont idle at all. I have to give the car gas to even stay running. The pvc hose on the intake wont make it do that. I say its missing but it may just be running rough i dont really know but it wont idle and I dont think i will be able to drive it up on my trailer now to get it home to fix the problem
Old Nov 1, 2007 | 11:35 PM
ESG-642T's Avatar
ESG-642T
Buyer Beware
Default RE: misfire
ORIGINAL: v6stang07
More detail on this half of an exhaust?
and,
What about this PVC hose?
Old Nov 2, 2007 | 09:58 AM
mustangcrazy87's Avatar
mustangcrazy87
Default RE: misfire
I just fixed this problem on my car. It ended up being a burned wire that was on the exhaust. If you have a tuner set the car back to stock tune and drive it for a good 20-30 minutes. You will get a blinking check engine light. Then use your tuner to find out which one is misfiring. It should be a P030# code. Then if that comes up check the plug and wire for that cylinder.
Old Nov 2, 2007 | 10:03 AM
Derf00's Avatar
Derf00
Gentleman's Relish
Default RE: misfire
ORIGINAL: mustangcrazy87
+1 i've run into this several times. It's usually on the passenger side header where it occurs. Start there. If you find a white powdery substance on a plug wire where it comes in close proximity or contact with metal (or the boot itself has it) that's caused from the arching.
Old Nov 2, 2007 | 12:19 PM
v6stang07's Avatar
v6stang07
Default RE: misfire
half exhaust meaning my passenger side exhaust goes manifold, h-pipe, flowmaster, tip
my driver side goes manifold (broken off at the flange and not connected to the rest of my exhaust
i know the the pvc hose will make the car run like and it ist that nor is it disconnected, and for a reference it is running way rougher than that and im not sure if i could even drive it at all
Urambo Tauro
Jun 10, 2016 03:28 AM
Omgitsa88Stang
Oct 5, 2015 07:33 AM
bconboy
Sep 21, 2015 12:52 PM
chrisc
Feb 10, 2006 10:16 PM
ghoste
Sep 7, 2005 11:42 AM
