3.8L to 5.0L
RE: 3.8L to 5.0L
You asked about the 4.6 in the pm, then a 5.0 here. The 4.6 will be eaiser then the 5-0. You will need engine, trans and all wireing. Also supporting mods, rear end, driveshaft. However what do you want to do to the car? why not just throw on a s/c?
RE: 3.8L to 5.0L
i was tryin to decide which would be easier to swap out. i asked you about the 4.6 cause you had mentioned that you've done one before. i want to swap because the engine i have now has high milage.
RE: 3.8L to 5.0L
In some states like California you have to use the engine that was in production with that car. The 5.0L has not been used since 1995 and thus being you can not legally get away with putting a 5.0L in anything newer in a state that regulates that such as California. Thats not saying that you can still get away with it, every time I had an inspection/smog they didnt care what I had.
For california the rule is you can use the same engine offered in that year and anything newer than that. For say a 1983 Mustang could use a 3.8L V6 or a 5.0L V8 or a 4.6L or 5.4L offered in newer cars.but couldnt use the 200 I-6 offered in 79' (I think it was a 200ci.) As long as you keep the emissions the same as offered with the engine/year you are using.
You could even put an Acura 2.2L in there if you had all the smog crap for it.
Always check your local laws. Personally I would suggest a 4.6L or 5.4L build.
-Eric-
-Eric-
RE: 3.8L to 5.0L
ORIGINAL: chiskater19
RE: 3.8L to 5.0L
ORIGINAL: LilRoush
5.0L is a worse motor to start with if you already have the 99-04 3.8L in there.
