engine swap...
Old Nov 6, 2007 | 11:08 PM
00mustang's Avatar
00mustang
Default engine swap...
if i wanted to go with a 4.2 L from www.precisionengine.com is it a straight swap or is there anything else im gonna need to do this? and if i add a supercharger wht kinda numbers could i be looking at getting? this is not something i plan on doing soon maybe after i get my car paid of, but i do want to get some ideas flowing... any help or opinions would be great... thanks in advance!
Old Nov 6, 2007 | 11:30 PM
HARFORD's Avatar
HARFORD
Default RE: engine swap...
i heard somewhere 4.2's push like 225 or somewhat. with a sc thats a pretty quick stang. i found some articles more in depth on the v6power . net site, but a few ppl have done it here and could tell you more. to my understanding ideally the 4.2 is like a bored out 3.8 .... same block. unless there are diffrent 4.2 L's out there.
Old Nov 7, 2007 | 11:33 AM
NeoTokyo's Avatar
NeoTokyo
Its the same block and everything will go on from your old engine just fine.
They have a steel crank and if he used any kind of good connecting rods and ballanced it then you can get about 700hp out of those before they scatter, if the crank is nitrated then about 850-900. Its a lot of prep work to make that kind of horsepower and its best to use longer rods such as 6.2" so that there is less pressure on the piston skirt.
I just checked their site. Its all stock, I really wouldnt go higher than 350hp out of that. Its also $1300 bux with a $475 core..... You really should just get the internal kit from Supersix and then have a machine shop assemble the shortblock for you. Get some heads and port them, port mach the intake and then get to work at swapping everything over.
SSM's price on their forged longrod 4.3L stroker kit (Internals)is $1775 I think thats a better way to go so that you can make the power that you will regret not having later.
Nick Oliver
Oct 17, 2018 04:22 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
rksnow1
Sep 14, 2015 08:46 PM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
