150mph
Old Nov 18, 2007 | 11:03 PM
TheMichiganRA's Avatar
TheMichiganRA
Default 150mph
I want a speedometer that goes up to 150mph. Is there anyway we can have one in our V6s? Can we use a SCT or program it on our chip somehow? I know I'll hit over 120mphmore then a couple times and I'll want to know how fast I'm going. What do I need to change it over?
Old Nov 18, 2007 | 11:20 PM
HornyHornyHippo's Avatar
HornyHornyHippo
Default RE: 150mph
well the only time id ever ever go over 120 is either on the track or on the dyno. And i know if oyu access the diagnostics you can have the digital spedometer. But that requires turning on and off the car, and once oyu turn the car off it goes away. You probably know all of this. But at least itll tell you how fast your going when its actually safe to go that fast. (youll never need it 24/7 unless you play on going 120+ on the street, then thats just plain retarded)
Old Nov 18, 2007 | 11:48 PM
alexr's Avatar
alexr
Default RE: 150mph
did you remove the govenor? if not your car tops out at about 109 anyway so you wouldnt ever need a speedo that is higher than 120
Old Nov 18, 2007 | 11:49 PM
ESG-642T's Avatar
ESG-642T
Buyer Beware
Default RE: 150mph
Without getting super technical yes it can be done...
Mach 1 / Bullit gauges have been done also!
Old Nov 18, 2007 | 11:56 PM
HARFORD's Avatar
HARFORD
Default RE: 150mph
go ahead and put one in it would be ................. unique ............... in a sense. if the cobra odometers are 150 get them or the machs ( silver ) that would be a nice add on
Old Nov 19, 2007 | 06:45 AM
MUSTANG042004's Avatar
MUSTANG042004
Default RE: 150mph
ORIGINAL: ARdoller
I have my govenor on and it dosn't top out at 109, more like 118 for me.
Old Nov 19, 2007 | 09:02 AM
amrcnidyot's Avatar
amrcnidyot
Default RE: 150mph
ORIGINAL: MUSTANG042004
ORIGINAL: ARdoller
thast because the governor is 118 for at least 99-04. im not sure about any other years.
and like VCS said, it can be done, your speedo might be off a bit and it will take a lot of work to get everything working right but it can be done. i personally would go for a set of cobra gauges. 160mph speedo..not like youd ever need it, and WHITE FACED...much better than the greyish color of the v6 and gt gauges. you would also need a tuner to shut of the governor if you are planning on using the higher speedo.
as a side note, there is no reason to be going that fast..your not going to be going that fast on a track, you would never hit that in a quarter mile. your going to kill yourself or somebody else if you do that on the street.
Old Nov 19, 2007 | 09:58 AM
ESG-642T's Avatar
ESG-642T
Buyer Beware
Default RE: 150mph
ORIGINAL: amrcnidyot
ORIGINAL: ARdoller
+1 besdies their is no point in the climb it would take a stock or even bolt on v6 to get to 150
Old Nov 19, 2007 | 11:37 AM
Xemeth's Avatar
Xemeth
Default RE: 150mph
The 1/4 mile will be way over before you ever reach 150. Not entirely sure about MPH and ET conversions, but I you'll need to be running 11's or 10's before you trap 150.
Old Nov 19, 2007 | 11:39 AM
alexr's Avatar
alexr
Default RE: 150mph
ORIGINAL: ARdoller
oh, well mine, and i assume the rest of the sn95 v6's top out at about 109.
