adjusting headlights?
Old Nov 29, 2007 | 11:55 PM
leterbuk2's Avatar
leterbuk2
Default adjusting headlights?
I know this ? has come up alot, but im still lost. I think Im retarted. I have a 96 v6. I cannot find where the headlight adjuster is at. Ive seen a couple places say it is a 4mm bolt and some say its a screw. I couldnt find either one. Does anyone have a pic of where it is at, or really good instructions? thanks
Old Nov 30, 2007 | 08:46 PM
johnt2k7's Avatar
johnt2k7
Default RE: adjusting headlights?
right on top of the headlight housing its a allen hole with a philips in the bottom ford sells a special tool that is a llen with a philips on the end but if you have either one of the two then you can adjust them
it is a black plastic hole in the top of the hosing so dont strip it out take it easy on it or you are ****ed
Old Dec 1, 2007 | 02:16 AM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Yeah i stripped mine, but it got stuck right where I want it, damn i'm good. Didn't take hardly any pressure to strip it either.
Old Dec 1, 2007 | 02:31 PM
v6stang07's Avatar
v6stang07
yea be careful not to strip it out and there is a guide line on where to adjust them to in the manual
I believe they should be parallel and the same height as on the car at 25'
cr620
Oct 3, 2022 10:18 PM
baddog671
Jul 26, 2016 01:20 PM
UrS4
Oct 3, 2015 06:23 AM
winner99
Sep 30, 2015 07:04 PM
Drastang
Sep 29, 2015 03:31 PM
