Door ajar sensor?
Old Dec 10, 2007 | 01:27 PM
blknismo180's Avatar
blknismo180
Default Door ajar sensor?
okay my sensor reads that my door is open...... i need to know where that sensor is and pull it so i can replace my interior dome light andhave it work again....
this is for my driverside door.
anyone know where it is...?
Old Dec 10, 2007 | 07:59 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Default RE: Door ajar sensor?
It's in the latch itself. It may be a seperate part, but that's where it is.
Old Dec 11, 2007 | 02:20 AM
blknismo180
i already took off the door panle and cant find the damn sensor!
lol
RYAN do you know wut it looks like?
or how big it is?
Old Dec 11, 2007 | 03:12 AM
RyansQuick6
Reverse Gear Member
I can't remember lol. Trace the wires, you sh.ould only have one set going to the latch itself. The door lock actuator is in the bottom of the door, so ignore it. I'm offshore as of today until the 21st, so I can't go look at mine or check my manuals.
Old Dec 11, 2007 | 04:44 PM
blknismo180
there are three wires going to that area......
one is a black connector the other white....whn i unplugged them the door did not want to lock....
there was one black 1 did not see the connector but did not know how to take it off....
Old Dec 11, 2007 | 08:04 PM
RyansQuick6
Reverse Gear Member
The one you unplugged was the door lock actuator, but until I can look at something to reference I can't really tell you anything more.
I have seen a few topics where people sprayed some wd-40 in their latch and it loosened up that switch and made it work fine, so give it a shot.
Old Dec 11, 2007 | 08:25 PM
amrcnidyot's Avatar
amrcnidyot
it is probably just stuck. mine did it a while back and i heard it is a fairly common problem. spray some wd40 inside the lock from the outside. dont be afraid to spray too much. then shut the door and open it and spray more. do that a couple times and see if it works then. it worked for mine and ive probably been going at least a year without another problem.
Old Dec 12, 2007 | 01:46 AM
blknismo180
well the problem i have is more electrical....i found out from a ford master tech that my door was open..... well the sensor was reading it as open... he said remove the sensor and itll say its closed and the dome light wont be on all the time and you wont hear a ding when your in the accessory position....so im trying to find that sensor, pull it and replace my dome light....lol
i hope this helps clerify my question.
Old Dec 12, 2007 | 11:48 AM
cominus's Avatar
cominus
Yeah I just had this problem the other day.
Old Dec 12, 2007 | 02:50 PM
amrcnidyot's Avatar
amrcnidyot
ORIGINAL: blknismo180
how do you know its electrical? unless you pulled the sensor and tested it i dont know how you would know.
