Door ajar sensor?
Old Dec 12, 2007 | 03:46 PM
blknismo180's Avatar
blknismo180
Default RE: Door ajar sensor?
ORIGINAL: amrcnidyot
ORIGINAL: blknismo180
well the problem i have is more electrical....i found out from a ford master tech that my door was open..... well the sensor was reading it as open... he said remove the sensor and itll say its closed and the dome light wont be on all the time and you wont hear a ding when your in the accessory position....so im trying to find that sensor, pull it and replace my dome light....lol
i hope this helps clerify my question.
how do you know its electrical? unless you pulled the sensor and tested it i dont know how you would know.
ummm actually i did test...with a ford diagnostic tool wich tested all the sensors and it came up as the door was still open even when it was closed.
so it is electrical because my door closes but reads that its open constantly...
Old Dec 12, 2007 | 07:36 PM
amrcnidyot's Avatar
amrcnidyot
that doesnt mean its electrical, thats exactly how mine was. i could shut the door but the car thougth the door was still open.
Old Dec 13, 2007 | 02:57 PM
blknismo180
so how did you fix your problem and
wut tool do you need to take the door jam off?
Old Dec 13, 2007 | 04:09 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Spray WD-40 in it and it will let the circuit open causing the light to go off when the door is closed. it's electrical because it's stuck, so unstick it.
Old Dec 14, 2007 | 01:16 AM
amrcnidyot's Avatar
amrcnidyot
you dont need to take anything apart,
it is probably just stuck. mine did it a while back and i heard it is a fairly common problem. spray some wd40 inside the lock from the outside. dont be afraid to spray too much. then shut the door and open it and spray more. do that a couple times and see if it works then. it worked for mine and ive probably been going at least a year without another problem.
Old Apr 6, 2019 | 10:28 PM
Amanda Lawrence Morquecho's Avatar
Default Thanks!
WD40 worked for ours too. Try this first.
JonnyThrice
Jul 19, 2019 07:44 PM
sandcracker21
Sep 23, 2008 09:45 PM
disdicbig1
May 15, 2007 02:19 PM
88 GT CONV
Feb 11, 2007 11:44 PM
LOUDexhaust
Jul 12, 2006 02:26 AM
