where is the clutch master cylinder located on a 2000 v6??
Old Dec 14, 2007 | 06:17 PM
highoutputv6's Avatar
highoutputv6
Default where is the clutch master cylinder located on a 2000 v6??
im looking everywhere for the clutch master cylinder and i cant find it..
is it some how linked to the brake master cylinder or something?
help me out thanks!!
Old Dec 14, 2007 | 07:16 PM
Weeman's Avatar
Weeman
Default RE: where is the clutch master cylinder located on a 2000 v6??
Clutch master cylinder? I've never heard of that but I'm not crazy knowledgable into every single part in the engine. The only master cylinder that I've heard of is part of your breaking system. That is located directed in front of the driver, on the firewall, inside the engine compartment. Maybe that helps? *confused*
Old Dec 14, 2007 | 07:29 PM
highoutputv6
its a 2000 v6, it has a hydrolic clutch, no cable, they have a clutch cylinder with brake fluid in it, like kind of a resevoir, and i cant find it
Old Dec 14, 2007 | 07:32 PM
alexr's Avatar
alexr
yes. its back near the master cylinder, its really small. imagine that the clutch pedal went straight through into the engine compartment, this is where you'll find the clutch master cylinder and clutch reservoir.
Old Dec 14, 2007 | 08:02 PM
highoutputv6
soo..... look under the brake master cylinder and booster?
lower down, and its attached to the firewall correct?
Old Dec 14, 2007 | 09:43 PM
stangfreak283's Avatar
stangfreak283
on the firewall right next to the brake cylinder. like ARDoller said it should be straight down from where the clutch pedal runs.
Old Dec 15, 2007 | 12:24 AM
mooses's Avatar
mooses
since when does a 2000 v6 have a hydraulic clutch?
Old Dec 15, 2007 | 12:49 AM
Xemeth's Avatar
Xemeth
I'm almost positive all Mustangs before 05 were cable clutches.
Old Dec 15, 2007 | 02:30 AM
97tunedmustang's Avatar
97tunedmustang
wow people who don't know what they're talking about should probably just not talk and give incorrect information.
pre-05 basicallyall mustangs have a cable clutch! aside from a few back inthe 60's that were hydraulic, thats about it. You're having a hard time finding the clutch master cylinder because it doesn't exist on your vehicle.
Old Dec 15, 2007 | 08:05 AM
alexr's Avatar
alexr
ORIGINAL: 97tunedmustang
a hydraulic clutch swap isnt all that uncommon.
