rpms
Old Jan 4, 2008 | 10:49 PM
aj552's Avatar
aj552
Default rpms
ok, here is another dumb problem. after warming the car and drving around for a few miles, when i shift, lets say from 2-3 while going at 3000 rpm's the thing jumps 300-400 rpm's sometimes when i presss the clutch.
and another thing is sometimes my car has a mind of its own O_O............
by that i mean after it jumps and i leave it in 2nd gear the car just keeps on going, it seems like its giving it self gas (when im not)
dose anyone know what the problem is?..........and or how to fix it
thanks
Old Jan 4, 2008 | 10:58 PM
aj552's Avatar
aj552
Default RE: rpms
and sometimes the rpms dont even drop below 1................the only thing to fix it is to turn the car on and offf..............but evantually it comes back
Old Jan 4, 2008 | 11:53 PM
eaglecatcher's Avatar
eaglecatcher
Default RE: rpms
maybe youre throttle cable is getting stuck somewhere...
Old Jan 5, 2008 | 12:04 AM
aj552's Avatar
aj552
Default RE: rpms
thats what i thought, it was a little loose
but i fixed it
Old Jan 5, 2008 | 12:20 AM
l_shizzle_l's Avatar
l_shizzle_l
Default RE: rpms
Clean your IAC(idle air control)
Old Jan 5, 2008 | 12:26 AM
aj552's Avatar
aj552
Default RE: rpms
personally i really dont think that is the problem
it only happens when the engine is warmed up.
Old Jan 5, 2008 | 05:39 PM
92lxsleeper's Avatar
92lxsleeper
Default RE: rpms
if you already fixed the loose cable, go ahead and shoot some thick penitrating lube down the accelerator cable housing, and on the butterfly on the throttle body.
Old Jan 6, 2008 | 01:46 PM
aj552's Avatar
aj552
Default RE: rpms
ok guys now im going crazy, i cleaned my idle air control, and now the freakin service engine soon light is on.
so any more suggestions
but cleaning the IAC did the trick with the rpm problem,
thanks l_shizzle_l
Old Jan 6, 2008 | 02:12 PM
92lxsleeper
Default RE: rpms
now clean the MAF sensor and the TPS sensor. and run codes.
Old Jan 6, 2008 | 02:40 PM
aj552's Avatar
aj552
Default RE: rpms
im stupid but what is a maf and TPS sensor?
thanks
