rpms
Old Jan 6, 2008 | 03:39 PM
usermst9673's Avatar
usermst9673
Default RE: rpms
maf is mass air flow sensor located in your air intake and tps is the throttle position sensor located by the throttle body
btw you can pull codes on your car without a reader. Just with the key out of the ignition hold the mileage reset button and continue holding it while you stick the key in and start the car. it will cause your gauges to sweep and then press the button and you will see different things pop up. the one your looking for is (dtc) if there are no codes it will show (dtcnone) otherwise read the codes and post them back on here and i will tell you what they mean.
Old Jan 6, 2008 | 04:25 PM
aj552's Avatar
aj552
Default RE: rpms
ok guys everything is all good
its was the TPS sensor
i guess some lube sliped in from trying to lube the throttle body
thanks guy's
CS2007
Jun 25, 2019 09:45 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
Sixer4Life
Oct 12, 2015 04:26 AM
Omgitsa88Stang
Oct 5, 2015 07:33 AM
lmurf60
Sep 24, 2015 10:07 PM
