When to flush fluids?
Old Jan 18, 2008 | 04:11 PM
robinson209's Avatar
robinson209
Default When to flush fluids?
After how many miles should you start flushing your fluids?
Old Jan 18, 2008 | 04:18 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Default RE: When to flush fluids?
ORIGINAL: robinson209
Brake fluid every two years
Coolant every two years
PS fluid every36K miles
Oil every 3-4K miles
Tranny fluid every 60K miles Manual (30K miles Auto)
Rear Difffluid every 60Kmiles (Both auto and manual trannies)
Did I miss any? [:-]
Old Jan 18, 2008 | 05:02 PM
robinson209
Thanks for the help buddy. Looks like I have some work to do. I bought my car used off a girl who prolly did nothing but change the oil...
Old Jan 18, 2008 | 05:26 PM
02MustangV6DD's Avatar
02MustangV6DD
Well then how many miles are on the car now?
Old Jan 18, 2008 | 05:48 PM
robinson209
It has 123,000 miles but she runs like a champ. Nonetheless I'm still going through maintenace work to be on the safe side because it was used when I bought it a few months ago.
Old Jan 18, 2008 | 06:04 PM
mustangman02232's Avatar
mustangman02232
why or how would you flush brake fluid or power steering fluid[&:]
Old Jan 18, 2008 | 06:10 PM
02MustangV6DD
Easy, you that the car up, disconnect a line and let it pump out, turn your wheels back and fourth, put line back on and fill er up. Brake fluid you just let it all run out, or you can open the bleeder screws, and pump it all out.
Anyways, I would be carefull about the transmission. 123k might not seem like alot, but if the trans has never been flushed before i would NOT do it. Your taking away all the clutch debris thats holding it togther. Get a carfax and see if it has had any service done, or call the dealership she bought it from and ask for old services. I DEF. Would not flush it, maybe just pan and filter, but not flush, then your getting out all the old stuff inside.
Old Jan 18, 2008 | 06:17 PM
robinson209
Wow I would have never guessed that about the tranny. Thanks again guys for help! I'll look into it before I have it flushed.
Old Jan 18, 2008 | 06:22 PM
mustangman02232
that sounds completely useless[8D]
Old Jan 18, 2008 | 06:38 PM
robinson209
Can you tell me why it is useless please?
