Emissions testing..
Old Jan 21, 2008 | 12:58 AM
sir lancelot's Avatar
sir lancelot
Default Emissions testing..
If i were to get pypes minicats welded into an o/r h pipe would i pass inspections??
Old Jan 21, 2008 | 01:23 AM
cobra232's Avatar
cobra232
Default RE: Emissions testing..
you should given the O2 sensors are all hooked up
Old Jan 21, 2008 | 08:43 AM
LilRoush's Avatar
LilRoush
If you live in a state that checks visually and with a sniffer, then NO, you will not pass. You are required to have stock or direct stock replacement cats - and the same number of them (4).
Old Jan 21, 2008 | 09:40 AM
sir lancelot
Do any of you guys know what type of emissions testing they do in texas? Or if they even do test?
Old Jan 21, 2008 | 09:46 AM
Xtasy305's Avatar
Xtasy305
Here found something...
http://www.txdps.state.tx.us/vi/insp.../item_insp.asp
Is your vehicle required to be emissions tested?
All Texas registered vehicles are required to receive an annual inspection. All inspections include a comprehensive safety inspection; however some vehicles are required to have an emissions test in addition to the safety inspection.
Old Jan 21, 2008 | 10:58 AM
l_shizzle_l's Avatar
l_shizzle_l
No testing for me but i allready knew that.
Old Jan 21, 2008 | 12:13 PM
LilRoush's Avatar
LilRoush
ORIGINAL: sir lancelot
Texas is tight. I lived there four years with vairous mustangs. It vaires county by county whether or not they make you pass a sniffer, but all do pretty tight inspections. Any aftermarket parts are usually seen - especially when it comes to exhaust and pollution control stuff.
Old Jan 22, 2008 | 10:13 AM
sir lancelot
Ilive in harris county. It says that there is OBDII and ASM testing. What exactly are these?
[IMG]local://upfiles/75421/002E914246214FBF89F1F927CB0FFE9F.jpg[/IMG]
[IMG]local://upfiles/75421/1FD646E4435A4BB79DDEB03C21659A1F.jpg[/IMG]
Old Jan 22, 2008 | 12:37 PM
LilRoush's Avatar
LilRoush
It means you better have a working EGR, all four 02 sensors and all four factory cats in good conditionand hope you pass. The OBDII part means they check to make sure you didn't delete anything (EGR delete, O2 delete etc...)
jpplaw
Mar 19, 2025 08:53 AM
mrtrodonet
Sep 19, 2020 03:12 PM
mrappe
Sep 26, 2015 10:16 AM
mltdwn12
Sep 23, 2015 08:54 AM
rksnow1
Sep 14, 2015 08:46 PM
