power increase
Old Mar 28, 2005 | 01:41 AM
blindoboy87's Avatar
blindoboy87
Default power increase
how much power do you guys think ill get out of my 2.3 if i port and polish it, buy a new header, cam, chip, and msd distributor/ with new plugs and wires??? why would i do this u ask?? because my mother sucks and wont let me do an engine swap out of an 88 t-bird turbo coupe!!! > that and is it really worth it?
Old Mar 28, 2005 | 02:26 AM
Jugador's Avatar
Jugador
Default RE: power increase
honestly....that's a losing battle. if you have money to burn and want to make like 20 or so horsepower, you can, but i'd just save your money for something fast later on down the road.
Old Mar 28, 2005 | 11:15 AM
blindoboy87
one thing im prety sure of tho is that if i could eventually swap a 2.3L turbo into it the parts should interchange within eachother..... as long as the turbo engine isnt any bigger than the non-turbo it should work. also, the otehr day i found a battery terminal peice in the back of my car and noticed that the battery gauge keeps fluctuating between normal and where its about to die but it starts every time.... think that the terminal pieces have to be replaced?
Old Mar 28, 2005 | 02:08 PM
Jugador's Avatar
Jugador
what year is your car? cause if it's dual plug, pretty simply, it won't swap over without you having to do some work. but if you're pre 91, you should have a very similar head minus the inconel valves, so if you are going to use anything, buy a turbo head and work it so you don't reuse the ported head later and end up with burned valves. on the header issue, i wouldn't waste the time. as for the cam, you probably should think about getting a ranger cam and followers from a dual plug engine because it's a roller cam and will give a little more power for not very much money if you know where to look.
Old Mar 28, 2005 | 05:52 PM
blindoboy87
yea my cars an 89, if im gonna buy the turbo head where can i get it from? not too many junk yards out here have fox bodies
Old Mar 28, 2005 | 08:55 PM
Jugador's Avatar
Jugador
online classifieds...check out turboford.org or ebay even
Old Mar 29, 2005 | 06:10 AM
I G Joe's Avatar
I G Joe
Ebay has plenty turbo heads. i am now swapping a Turbo 2.3L into my current N/A 2.3L =D sounds like you get to have the fun i am. cept my T2.3L is out of an 88 Merkur XR4Ti that poor thing was in bad condition cept the engine =D. who knows maybe if i get a new header i can give you the one i have. and yes parts are interchange able you can make the 2.3L you have now a turbo engine easy just better to do a swap =-D
jwog666
Dec 27, 2021 08:09 PM
jrrhd73must
Oct 2, 2015 09:17 PM
KingRando
Oct 2, 2015 08:06 AM
Sep 25, 2015 06:58 PM
