Heating up a bit
Old Feb 6, 2008 | 11:03 PM
jlgroom's Avatar
jlgroom
Default Heating up a bit
Hi people,
Got a 95, 3.8L. Anyways no code good compression, on the normal gauge however its going up to the m on the normal gauge it use to go to the r before but its going to the m then the fan kicks on and it drops all the way in front of the n. Just wondering if I should change the coolant or what step I should take it runs fine and the radiator was installed 8 mo's ago
Old Feb 7, 2008 | 04:08 AM
Matt's 95 Stang's Avatar
Matt's 95 Stang
Resident Ginger
Default RE: Heating up a bit
I dont think you have any problems. You can try changing the coolent but I would say wait until you reallly need to. As long as the fan kicks on (like its suppose to) then it should be all good. The only think I can think is that you might be starting to have a head gasket problem (very commen, even expected) with our years.
Matt
Old Feb 7, 2008 | 04:46 AM
The Yellow Pinto
Guest
Posts: n/a
maybe the thermostat is crapping out? my work truck had the same symptoms....changed the termo, and the temo ran more normal after than..
jwog666
Dec 27, 2021 08:09 PM
PaulH2
20
Jan 31, 2016 09:48 AM
Explosive
Oct 2, 2015 07:45 AM
folivier
Oct 2, 2015 05:34 AM
Sep 29, 2015 03:23 PM
