Rear Axle ABS/non ABS
Just looked in the truck, will a ABS style axle work on a Non ABS rear?
she picked it up from the junkyard, so if it won't work then i'll go back and see if they have a non abs..
96 V6 7.5 rear 2.73 gears
RE: Rear Axle ABS/non ABS
It will work, I did it on mine and many others, sn-95 and new edges. What "cross shaft bolt" are you talking about? Are you talking about the little bolt that holds in the kingpin?
they should work no problem. axles are not ABS specific. the Tone Ring is on the ringgear/differential assembly.
you might have axles from a newer rear that was put into an older stang. 99+ are too long for94-98 and Fox. 94-98 axles will work in a fox.
i don't see how you are hitting thedifferential cross pin. doesn't make sense
ORIGINAL: cobra232
11-10-2015 11:39 AM
09-10-2015 08:39 PM
Dragonus18
09-09-2015 01:21 AM
