Re-doing Drivetrain!!!!!
ORIGINAL: 02MustangV6DD
When you do a brake tourque your tires will break loose and spin at 1500 rpms, with a higher stall it will be, well... higher. It allows much harder launches
ORIGINAL: cobra232
wrong. hp and torque have everything to do with stall speed. a big block will stall the converter higher than a 3.8 because it has more torque. a converter is a torque multiplier.
a 3200 stall is not too high for a 3.8. my 2500 feels no different than stock. going to an Edge converter 3200 single disk lockup. i start breaking traction at about 1800. if i had a bigblock it would stall higher.
rpmxtorque makes overall stall speed. not rpm alone
anyone that has a 3000 or higher stall on their V6 will tell you that is the only way to go
about $600 for one of them but sometimes you can find them on EBAY cheaper
ORIGINAL: JKs95stang
No, the horsepower has nothing to do with the stall speed of the converter. With the 2500 stall, that's about right, you should start breaking traction around 2k - 2200. Maybe 2800 - 3000 stall, might be what you are looking for if you drag race your ride! I wouldn't go higher than 3000 with a daily driver! Good Luck!
I know that much, but my 2500 isnt at 2500, more like 2000-2100. If i had like 50 more at the wheels it would be more like 2500 right?
ORIGINAL: amrcnidyot
i found another source that says that all you have to do is switch the yoke. the gt/v6 driveshafts are also interchangable. not the cobra tho
Tim, thanks for the help, im sure about a 3200, and pretty sure about the one you reccomended but am still talking to the guy at oregon because a good price. Now go to my other post about my new engine!
Sep 17, 2015 07:32 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
