Re-doing Drivetrain!!!!!
Well im finally getting a new stall, goin for a 3200 from Oregon Performance Transmission, along with a trans cooler. Also looking for an Aluim. Driveshaft, cant find one for the Auto, but cant you change out the yokes?? For the rear, my buddy crashed his 04 so im taking his auburn out for $100 with less than 15k on it. Puttin my 3.73's back in too.
Is a girdle worth the $140?
Can the Yoke be switch on t-5/auto driveshaft?
Good size stall?
What do you think? What type of transscooler? i was thinking about
http://store.summitracing.com/partde...p;autoview=sku
Good size stall?
You can get a transcooler from autozone for cheaper and u dont have to w8 on it.
As far as the drive shaft They really dont do much but if u do get it u should get the holder.(i.e. http://www.partsmaxx.com/MUSTANG-DRI...P1919C195.aspx )
I dont know of changing out the yokes.
I think i am getting the same stall.
If U have not U should get a shift kit to add on the power,and tuner for the 3.73s
Edge racing converters Street edge 3200 single disk full lock up is the best out there
www.edgeracingconverters.com
I got the saftey loop, but i have no need for it, found at a swap meet for $20.
How much are those converters?
I have a transgo shiftkit in already and a 2500, but it didnt seem to do much for me.
If you would be so kindly to explain how the stall is determined....i know if you put a 3200 in a stock car it will be a lot lower stall, and the more hp you have the higher or closer it will be to what its supposed to be.
ORIGINAL: 02MustangV6DD
Iwas just wondering... do you actually benefit from a higher stall if say you are going 30 mph down the road and floor it???? What about just idling and thenfloor itfrom a dead stop???
Or is it only good for getting off the line while holding the brakes down and giving it gas to reach the stall speed then releasing the brakes and taking off???
Please, someone explain this to me!
I know that much, but my 2500 isnt at 2500, more like 2000-2100. If i had like 50 more at the wheels it would be more like 2500 right?
ORIGINAL: JKs95stang
No, the horsepower has nothing to do with the stall speed of the converter. With the 2500 stall, that's about right, you should start breaking traction around 2k - 2200. Maybe 2800 - 3000 stall, might be what you are looking for if you drag race your ride! I wouldn't go higher than 3000 with a daily driver! Good Luck!
a 3200 stall is not too high for a 3.8. my 2500 feels no different than stock. going to an Edge converter 3200 single disk lockup. i start breaking traction at about 1800. if i had a bigblock it would stall higher.
rpmxtorque makes overall stall speed. not rpm alone
anyone that has a 3000 or higher stall on their V6 will tell you that is the only way to go
about $600 for one of them but sometimes you can find them on EBAY cheaper
