250hp V6
Old Mar 31, 2005 | 03:40 AM
almerick07's Avatar
almerick07
Default 250hp V6
Is 250hp without using a supercharger, turbo or nos realistic and if it is how should i go about doing it?
Old Mar 31, 2005 | 03:57 AM
Jimmz's Avatar
Jimmz
Default RE: 250hp V6
yes it is possible, you just need to get a lot of bolt ons. To get 250hp out of a naturally aspirated V6 you need to get exhaust (dual flows and off road h/x pipe),CAI, gears, headers, MAF, Diablo Sport chip, that'll get you close, but im not exactly sure it will get you to 250, but very close. Jus plan on spendin some $... ask 97stallion. Hes got a 97 v6 and his sounds like a v8 and runs like 13's or so in the 1/4, he'll kno what u need...
Old Mar 31, 2005 | 04:03 AM
almerick07's Avatar
almerick07
I figured it was, do you know if running a straight pipe is performance robbing? I'm running a straight pipe after the cat converter up and over the rear axel to maintain back pressure, im willing to run duals but my pipe sounds soooooo sooooo good right now it would be alittle depressing.
Old Mar 31, 2005 | 04:17 AM
Jimmz's Avatar
Jimmz
ummm its illegal to run straight pipes.... and you wont pass smog lol. Some say runnin straights does rob some of your h.p. but im not sure, id rather have flows or some type of muffler. I'd only do straits if I had an old muscle car...
Old Mar 31, 2005 | 04:54 AM
HRnB's Avatar
HRnB
Administrator
You can get an extra 90 HP's naturally asperated. Check this link out Almerick. www.supersixmotorsports.com
Old Mar 31, 2005 | 12:53 PM
almerick07's Avatar
almerick07
Honestly I would rather have a true dual system, but the straight pipes are legal...it is still cat back and passes texas inspection. thanks for the link, hotrods n booze. my mustang is a standard if that gives anyone else a better idea for what to do.....even though the super six stuff does look pretty neat.
Old Mar 31, 2005 | 03:26 PM
HRnB's Avatar
HRnB
Administrator
Bottom line with our V6 Mustangs. Ford chokes the shizzz out of them. We just need to do what ever we can to pass more air at a faster rate through our engines.
Old Mar 31, 2005 | 04:37 PM
tightdogal's Avatar
tightdogal
how much money would it take to bring a 6'er to 250 hp?
Old Mar 31, 2005 | 05:45 PM
HRnB's Avatar
HRnB
Administrator
ORIGINAL: tightdogal
Well, the SSM HiPo power pak is around 1,700.00 but I think it can be done for less.
Old Mar 31, 2005 | 06:12 PM
matthockey32's Avatar
matthockey32
I ♥ Acer
check out the sig. that is to the crank NA. with a better cam and a stroker kit i know 250 RWHP is possible. and i just got a 60 shot of NOS to top it off.
